*Pro
180 Kudos
Post 11 of 14
Re: shoulder slope subassembly
01-23-2013 06:15 AM in reply to: KMercier_C3D
Right, that figure he posted, you may not have seen it, shows the OP's shoulder slope criteria is not a simple direct relationship to lane slope.
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
www.ernstengineering.com
Distinguished Contributor
0 Kudos
Post 12 of 14
01-23-2013 06:16 AM in reply to: KMercier_C3D
thanks for all the input.
no, the shoulder doesn't match the lane slope all the time, only in certain instances where the lane slope is greater than 6%. between -1% and 6% the shoulder stays at 6%. from -1% to -5% the shoulder varies in relation to the lane slope. if the lane slope is -3.2% then the shoulder slope is 3.8%. at -6% and greater it becomes crowned. it is a pita. like i said, i've got a profile for the shoulder but any change in alignment or profile really becomes time consuming.
Dell Studio XPS 9100
Intel Core i7 CPU 930 @ 2.8GHz
12GB Ram
64 bit
C3D 2015
66 Kudos
Post 13 of 14
01-23-2013 06:19 AM in reply to: fcernst
I stand corrected. I had missed the *.png that was posted. Definitely an ideal situation for SAC and really a rather simple one at that. I'd still use Parameter References though and have the shoulder SAC have an input parameter of the lane slope and then the shoulder is calculated and generated from there.
Kati Mercier, P.E.
Co-author of "Mastering AutoCAD Civil 3D 2013"
AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
*Pro
180 Kudos
Post 14 of 14
01-23-2013 06:25 AM in reply to: KMercier_C3D
Yes, that would work through most of the criteria range, except for those steep lane slopes at the top of the criteria range, where it looks like he has a crowned shoulder that is smoothed with a fillet, which SAC could easily handle.
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
