Civil 3D Forum
Shifted Profile within Profile View
6 REPLIES 6
968 Views, 6 Replies
Frustration.....
I have an issue with a profile referenced into a plan sheet that is shifted when I view it in the plan sheet viewport.  The profile stationing is correct in the profile dwg file and in the plan sheet dwg it is referenced into.  But when I switch from model space to paper space in my layout sheet (the file the profile dwg  is referenced into) the profile moves to the wrong station within my profile view in paper space.
The profile start station is 0+00, but it shifts to -1+00 within the viewport of my layout sheet.
The scales are the same between the dwg files (50) and the Annotation scale matches the dwg scales.
6 REPLIES 6
mathewkol
I "think" I know what you mean.  I have a client with a similar issue.  Edit the profile view style and set the "Axis Offset" in the Grid tab to a value of 0.0.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
WHEN IS AUTODESK GOING TO FIX THIS!!!!  HOW MANY MORE RELEASES DO WE HAVE TO PAY FOR UNTIL THIS IS FIXED!!!!
(loud angry words)
I wish that made me feel better, but it really doesn't.
Keith
abbythralls
I cant believe we are at 2016 and still no fix?
kfarrell8PBPW
Working in 2022 and I am still having this issue. Have there been any fixes to this? When I make a pdf the profile views look correct so this is really only an issue while making revisions. My plan and profile viewports are set to 1"=50' and I have other viewports on the sheet set to 1"=10', when I remove the 1"=10' viewports and regen the profiles look correct.
mathewkol
in reply to: kfarrell8PBPW
Did you try the potential solution of editing the profile view style?  There have been no changes as far as I know if this style edit works.
Matt Kolberg
kfarrell8PBPW
If the axis offset is set to 0" the profile view looks fine but for this particular job we want to have the offset so this is not a solution. We will likely just change our other viewports to match the 1"=50' viewports and call it good.
Rail Community
