My shift key is not working in Civil 3D? When I want to remove something from a selection set I hold shift to remove it and it does not work? Or if I go to do Copy clip etc...
Solved by wfberry. Go to Solution.
RIght click on your command line select options and go to the selection tab and look at your selection modes.
Robert
It is not Nown/Verb or Shift to add... it is somehting else...
Been using AutoCAD for a while, was a AE for four years teaching / supporting it. Never seen Shift drop out like this...
Possibly the PICKADD or the PICKFIRST system variables need resetting.
Bill
Yes I should have restarted first thing know that is what I tell my users to do...
But that was not it, it was the PICKADD I set it to 0 then back to 2 and that fixed it. Must have been some lisp somewhere blown out and left it hanging...
Thanks Bill
