Civil 3D Forum
Shift Key not operating properly
9 REPLIES 9
Message 1 of 10
1727 Views, 9 Replies
Hi yall when I try to de-select an object (using grips) holding down the shift key I cannot. Does anybody know of a system Variable or setting that disables this handy feature? bty if I hold shift and right click my opsap menu comes up like it should so I believe the keyboard still operates.
Andrew
9 REPLIES 9
Message 2 of 10
Jeff_M
MAPIOPTIONS, General Tab, deselect the Shift+Left click Image select button
Message 3 of 10
in reply to: Jeff_M
I do not have a "general" tab in the dialog box that comes up when i enter mapoptions in the command line.
I have these tabs.
Task Plane
Current Drawing
Query
Save Back
Data Source
Multi-User
Sytem
Coordinate-Systems
Message 4 of 10
Jeff_M
Not Mapoptions.... mapIoptions for Map Image Options
Message 5 of 10
in reply to: Jeff_M
my bad!!! Your The Man!!!!!!! that did it thatnks
Andrew
Message 6 of 10
Timmis
in reply to: Jeff_M
Autocad MEP 2010 something happens when I want to collect as many items, always have to hold down the Shift
Message 7 of 10
Civil3DReminders
in reply to: Timmis
In options, in the Selection Tab look for Selection modes and check to see if the "Use Shift to add to selection" is checked. I personally prefer it set to this, a whole lot of reduced hitting the escape key during the day.
Christopher
http://blog.civil3dreminders.com/
Message 8 of 10
Sinc
in reply to: Civil3DReminders
I prefer leaving that option off, and I program one of the extra buttons on my mouse (Logitech MX Revolution) to behave like the ESC key, so I can hit the button on the mouse to deselect items.
Sinc
Message 9 of 10
Timmis
thanks,now my hard job will by not so hard
Message 10 of 10
in reply to: Jeff_M
Thanks, @Jeff_M! You solve my problem! 🙂
Rail Community
