a normal day is when i have a group of somethings selected, and when i hold shift and click some of those selected somethings, they will unselect. like, you window a group of objects, but then decide to de-select something.
now, when i have a group of objects select, and shift click, it doesn't de-select the object, my command line reads "1 image(s) found". how do i get the shift-click back to de-selecting something?
Solved by tcorey. Go to Solution.
I read this recently I will try and look it up for you... I rememeber there is a map setting you can disable to keep this from happening.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/1-image-s-found/m-p/2831495/highlight/true#M140853
imapoptions
general tab
turn off shift+left click
Raster Design would do this. If it's intalled go to the Raster Design Options dialog, User Preferences tab and uncheck the box for Shift+Left click image select.
John Mayo
i dont currently have that installed. is there a text prompt that pops up on the command line someone could post for me that enables/disables this feature?
For some reason in 2013, the Noun/Verb selection keeps turning itself off. In the Options, Selection tab, make sure that Noun/Verb Selection is checked.
my box was checked. i also tried unselecting, hitting ok, then checking it again. it still is saying the above quote.
thanks.
Mine did this the other day and a simple reboot of the program fixed it.
From the Command prompt, type MAPIOPTIONS, go to General tab, turn off the option to Shift+Left Click Image Select. Now Shift+Left click will de-select objects.
So we Shift+click to deselct objects in a selection set, we Shift+click to select grips of selected objects, and now we can Shift+click to select an image too! Isn't anyone thinking? What's wrong with Ctrl+click or Alt+click, if we need more clicking options?
Mark Green
Working on Civil 3D in Canada
I agree, that would allow you to have both features.
i Have a quick question for you: how did you figure out this solution? i mean is easy just to come to the forums to get the answers but i wonder if there is any other guides to find the commands that are not so common.
Thirty-five years of doing training and support for AutoCAD and DCA/Softdesk/Land Desktop/Civil 3D. Every time someone asks me a question, I learn something new. Some of it, I remember. 😉
