Distinguished Contributor
0 Kudos
Post 1 of 12
shift click
997 Views, 11 Replies
11-05-2012 06:16 AM
a normal day is when i have a group of somethings selected, and when i hold shift and click some of those selected somethings, they will unselect. like, you window a group of objects, but then decide to de-select something.
now, when i have a group of objects select, and shift click, it doesn't de-select the object, my command line reads "1 image(s) found". how do i get the shift-click back to de-selecting something?
From the Command prompt, type MAPIOPTIONS, go to General tab, turn off the option to Shift+Left Click Image Select. Now Shift+Left click will de-select objects.
13 Kudos
Post 2 of 12
Re: shift click
11-05-2012 06:24 AM in reply to: MonkeyTrainer
I read this recently I will try and look it up for you... I rememeber there is a map setting you can disable to keep this from happening.
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
13 Kudos
Post 3 of 12
Re: shift click
11-05-2012 06:37 AM in reply to: MonkeyTrainer
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/1-image-s-found/m-p/2831495/highlight/true#M140853
imapoptions
general tab
turn off shift+left click
-Dustin
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
245 Kudos
Post 4 of 12
Re: shift click
11-05-2012 06:38 AM in reply to: MonkeyTrainer
Raster Design would do this. If it's intalled go to the Raster Design Options dialog, User Preferences tab and uncheck the box for Shift+Left click image select.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
0 Kudos
Post 5 of 12
Re: shift click
11-05-2012 06:45 AM in reply to: jmayo
i dont currently have that installed. is there a text prompt that pops up on the command line someone could post for me that enables/disables this feature?
169 Kudos
Post 6 of 12
Re: shift click
11-05-2012 07:01 AM in reply to: MonkeyTrainer
For some reason in 2013, the Noun/Verb selection keeps turning itself off.  In the Options, Selection tab, make sure that Noun/Verb Selection is checked.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
0 Kudos
Post 7 of 12
Re: shift click
11-05-2012 07:21 AM in reply to: TRogers
my box was checked. i also tried unselecting, hitting ok, then checking it again. it still is saying the above quote.
thanks.
169 Kudos
Post 8 of 12
Re: shift click
11-05-2012 07:22 AM in reply to: MonkeyTrainer
Mine did this the other day and a simple reboot of the program fixed it.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
308 Kudos
Post 9 of 12
Re: shift click
11-05-2012 04:11 PM in reply to: MonkeyTrainer
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
267 Kudos
Post 10 of 12
Re: shift click
11-06-2012 06:37 AM in reply to: tcorey
So we Shift+click to deselct objects in a selection set, we Shift+click to select grips of selected objects, and now we can Shift+click to select an image too!  Isn't anyone thinking?  What's wrong with Ctrl+click or Alt+click, if we need more clicking options?
Credit where credit is due! Give kudos or accept as solution whenever you can.
