Civil 3D Forum
shift 3D polyline with slope
7 REPLIES 7
Message 1 of 8
LASSAADTH
1012 Views, 7 Replies
how i can offset a 3D polyline with slope, I explain I have a 3D polyline I want to offset with a slope of 3H: 2V.
Thank you for your answers.
Lassaad THALJAOUI
Infrastructure Engineer
Autodesk Product professional User
Civil 3D 2016 x64 / Windows 7 64-bit / 16GB RAM
7 REPLIES 7
Message 2 of 8
neilyj666
in reply to: LASSAADTH
Convert to a featureline and use a grading object - take a look at the Help
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 8
AllenJessup
Use OFFSETFEATURE. It will work on 3D Polylines too.
Allen
Allen Jessup
CAD Manager - Designer
Message 4 of 8
neilyj666
in reply to: AllenJessup
Probably a neater solution as it avoids the use of a Grading Object....as long as you know the difference between Slope and Gradient...Smiley Wink
Message 5 of 8
LASSAADTH
in reply to: neilyj666
this is perfect Smiley Happy
But I would love to go further, is't possible to shift with two different slopes, one at the beginning and at the end?
Thank you for all your answers.
Lassaad THALJAOUI
Message 6 of 8
AllenJessup
The help seems to lack any mention of it although it did in the wayback. The most important thing to know is that entering a slope give you the X over 1. So if you enter 3 you get a 3 to 1 slope. In the OPs case the slope would have to be reduced to 1.5 over 1 rather than 3 over 2.
Allen
Allen Jessup
Message 7 of 8
AllenJessup
 See:
http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesCUG/GUID-7C9ADB83-3E60-4111-8482-ACC1296...
for how to use the Variable option. You may need to turn the polyline into a Featureline for this.
Allen
Allen Jessup
Message 8 of 8
owenmull
To my knowledge, not using the OFFSETFEATURE command. It should apply one uniform slope for the entire line.
What I would do is convert the 3D Poly to a feature line as Allen said, and do a 3:1 grading for a very small distance (like 0.01') at the start, then the same thing at the end at a 2:1, and do a grading transition between them.
There may be another faster way, but that's what comes to mind right now.
HTH
-Owen
Windows 7 x 64 bit
Civil 3D 2017
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
Rail Community
