This may actually be a question for the general populus, but I'll start here:
Has anyone else ever had an issue with the Sheet Set Manager where it will actually cause the referenced drawing to change names? The issue I have been noticing is that the drawing name will change to include one of the tab names in the drawing (i.e. "C:\Prop Parking Lot" will change to "C:\Prop Parking Lot - Sheet 1"). There doesn't seem to be any consistency to this issue, either...happens to some drawings but not to others in the sheet set.
Thought? Ideas?
Thanks!
Solved by Joe-Bouza. Go to Solution.
I've not seen this happen randomly but there are various renaming options found on the "Rename & Renumber Sheet" dialog.
Review these settings.
Joe Bouza
