I've just completed my first sheet set (much easier than the previous way I approached plan set production) but have encountered a slight annoyance.
I have created 13 sheets at A1 and then an index sheet at A4, dragged the index sheet to the top of the SSM list and published to pdf. All the sheet size fields are then populated with the index sheet page size i.e. A4. If I remove the index sheet OR create an A1 index sheet then the page size fields all populate as A1.
Anyone any idea whats going on?? Can you mix different sheet sizes in a sheet set??
thanks
neilyj (No connection with Autodesk other than using the products in the real world)
Its difficult to determine not knowing what your field assignments are. Although, assigning a sheet number merely by moving up and down the list sounds odd. Can you post your dst file and Title block?
Yes you can mix sheet sizes, however you would have to publish separately with the appropriate page setup file, unless the PTPDF uses the default in the sheet - I'm not 100% sure. Are you using Page setup overrides?
Your Name
Your Name
You take today Off?
Your Name
Your Name
