Sheet set publish issue: Civil3D 2014 running on network. Publish to plotter named in page setup works on one computer (set up to use same Adobe pdf.pc3 file and full pdf page setup at 22x34 size) - one computer creates the pdf as 22x34 and another creates the pdf file as 18x24 size so it cuts off part of the sheet. Also have a 3rd computer that gets a "the current device does not support the requested media size" error when trying to publish from sheet set and nothing is created. This happens when trying to publish the same sheet set. All 3 computers display the same sheet details in the publish dialog box; which appear to be fine on review. Any ideas on what is the problem? Thanks!
Process: from Sheet Set Manager: Pick publish dialog box, publish to plotter named in page setup, highlight all layouts and change to page setup needed. All options picked in the same manner and 'no errors' shows in dialog box. Can do all 3 computers within minutes and get only one good result.
Solved by civilSD. Go to Solution.
This error will occur if different driver files are being called does eveyone work station point to a centrally located pc3 file? and does everyone have the same drivers.
I forgot about that.
In your SSm setup you have the ability to point to and overide setup file. I have one for each sheet size so everyone points to the same setup
Any help on this one?
I have been using sheet sets for several years. Recently one thing in my ss has become “disconnected”?
My template has my drawing settings with fields in the title block which are controlled by the ssm. However when I add a new sheet to the set,I use my template,(OR COPY AN EXISTING FILE FROM THE SET) I edit the titleblock info in the sheets properties dialog box by right clicking the file in the ssm. After finishing editing this info, When I save the file the fields don’t update to the edited info I just did?
Would you know what happened?
Thanks for any insight,
Mark
Wow, been a while but still have this issue, so yes I do have several custom fields. Also When I make an index (sheet list table) it doesn't use the info from the fields?
Thanks for any help.
"Also I can not get the plot to do a "Single Sheet File" PDF. Is there a trick to this?
All my PDF plots come out Multi Sheet File even when I pick Single Sheet File?
