C3D 2014. In my drawing, I have an existing ground surface, an alignment and some feature lines I used to create a profile view with an eg profile and some superimposed profiles. When I create the sheet set, I don't get any profiles in my profile views. Any help?
Solved by bf. Go to Solution.
Are you using Plan Production tools, or just creating your own sheets within Sheet Set Manager?
bf - what was the setting that fixed your problem? I have the same problem but the only fix is to synchronize my surfaces before plotting but this step cannot occur when plotting via Sheet Set Manager. IT has suggested setting the ground lines to "static" but that is not an option since I need them to update as grading changes occur and I also want the profiles to correctly linetype the lines as dashed lines.
For me, I realized that the profile views were displaying, but not in my current drawing. They were in the model space of the drawing I specified for all of the sheets.
probably too late to help but maybe helpful to someone else...
The issue in my case was that the profile view elevation range was set to 0 to 5
