I want to take the same set of plans, and create PDFs of two different sizes. One 11x17 set, and one 22x34 set. Is there an easy way to do this?
I do NOT want to create duplicate layout tabs.
Solved by Jay_B. Go to Solution.
Sure, create a Page Setup for 11x 17 pdf and a Page Setup for 22x 34 pdf in a dwt which is set as the Page Setup overrides file in and plot from SSM using each Page Setup override.
This steers me in the right direction, and ALMOST does what I want it to do. I may need to tweak my process a bit.
...and who accepted the previous post as a solution? I'm not saying the information provided was right or wrong, but *I* didn't accept it as a solution. Can anybody go around and do that to any thread?
Sorry but I don't have any means of figuring out how the thread got marked as solved.
If it's not the solution, simply select "options" on upper right and choose "Not the Solution".
BTW, What is it meant by "This steers me in the right direction, and ALMOST does what I want it to do."
What are you hoping to accomplish, that the page setup overrides option doesn't provide?
@Anonymous wrote:
@deltacoolguy wrote:...and who accepted the previous post as a solution? I'm not saying the information provided was right or wrong, but *I* didn't accept it as a solution. Can anybody go around and do that to any thread?
I did find "Not the Solution" in the options menu, but in this case I'm going to leave it. It does address what I wanted, and I believe gives a correct answer. I'm more curious at how/why it was done to begin with. Seemed strange to me.
What I meant by "almost" is that when you do this according to what you described you only get 'layout' and 'extents' in the plot area drop down in the Page Setup dialog box as options. I have my layout done in a slightly uncommon configuration and I think if I tweak what I do on my end just a bit that it will work fine. I did some tests and the result was skewed just a bit.
I also meant "almost" in the sense that I already have set-ups in each drawing for 11x17 and 22x34. 11x17 is the default for each sheet, and is what I will use the vast majority of the time. To my mind, it would/should be as easy as simply picking the already existing 22x34 set-up as an override option and leaving it at that.
The Discussion_Admin, some other Adesk employees, and Expert Elites all have the ability to do this. Most EE's will not do so until a post that is an obvious answer has not had any action for some time. I was surprised to see how quickly Jay's was marked in this thread when I saw it yesterday.
Your Name
