I am using C3D 2014. I have moved a sheet set to a new folder location. All the properties information shows correct links and all fields appear to function correctly. However, all the sheets in the SSM appear with question marks (?) on all of them. Does anyone know why this happens?
Solved by Joe-Bouza. Go to Solution.
Solved by CADEngr2014. Go to Solution.
The sheets are logged into the sheet set properties by filename path and expected layout. I SSM maybe holding on to the original file path. you can check and correct by RC a sheet>> properties and check the two fields.
Joe,
Thanks for your response. I was not clear what you meant by "RC a sheet"? Can you clarify?
