CADEngr2014
Message 1 of 4 (316 Views)
SHEET SET MANAGER
316 Views, 3 Replies
01-07-2014 02:18 PM
I am using C3D 2014.  I have moved a sheet set to a new folder location.  All the properties information shows correct links and all fields appear to function correctly.  However, all the sheets in the SSM appear with question marks (?) on all of them.  Does anyone know why this happens?
The sheets are logged into the sheet set properties by filename path and expected layout. I SSM maybe holding on to the original file path. you can check and correct by RC a sheet>> properties and check the two fields.
Joe,
Thanks for your response.  I was not clear what you meant by "RC a sheet"?  Can you clarify?
RightClick
Joe-Bouza
Message 2 of 4 (299 Views)
Re: SHEET SET MANAGER
01-07-2014 03:56 PM in reply to: CADEngr2014
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
CADEngr2014
Message 3 of 4 (271 Views)
01-08-2014 02:35 AM in reply to: Joe-Bouza
Joe,
Joe-Bouza
Message 4 of 4 (267 Views)
01-08-2014 04:09 AM in reply to: CADEngr2014
RightClick
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
