Civil 3D Forum
Sheet Set Manager - sheet set properties dialog box
3 REPLIES 3
Rbaltazar
288 Views, 3 Replies
Within SSM, when I rigth click on the sheet set and select "Properties" the dialog box will not open. Anyone ever come across this issue? SSM was operating normally and all of the sudden I am not able to open this dialog box to edit sheet set properties. Does this have to do with some sort of of system variable?
3 REPLIES 3
in reply to: Rbaltazar
it might have something to do with noun/verb selection being toggled off.
Dan
Also, SSM will not repond if there is not an open
drawing file (a blank drawing at minimum)
Joe
Rbaltazar
I did discover that it has something to do with my user profile (.arg file). I ended up doing a reinstall/repair hoping it would fix the issue. When I was running Civil 3d using the default .arg file, it worked fine. Once I loaded a custom profile, it stopped working. Have no idea where to go from here.
Rail Community
