Civil 3D Forum
Sheet Set Manager - sheet set properties dialog box
3 REPLIES 3
Rbaltazar
287 Views, 3 Replies
Within SSM, when I rigth click on the sheet set and select "Properties" the dialog box will not open. Anyone ever come across this issue? SSM was operating normally and all of the sudden I am not able to open this dialog box to edit sheet set properties. Does this have to do with some sort of of system variable?
3 REPLIES 3
dgordon
in reply to: Rbaltazar
it might have something to do with noun/verb selection being toggled off.
Dan
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Also, SSM will not repond if there is not an open
drawing file (a blank drawing at minimum)
Joe
Rbaltazar
I did discover that it has something to do with my user profile (.arg file). I ended up doing a reinstall/repair hoping it would fix the issue. When I was running Civil 3d using the default .arg file, it worked fine. Once I loaded a custom profile, it stopped working. Have no idea where to go from here.
Rail Community
