Salutations ~
When I publish the sheet set to PDF I have no problems. On another PC in the office, the function does not work. I am not sure how to fix this. Any direction would be appreciated.
Thanks.
Sometimes there is a problem with the PDF publishing, you should try with the Plot command and using the DWG To PDF.pc3 if the EXPORT command doesn't work.
