I am using C3D 2014. The question I have is regarding the Sheet Set Manager. Under the "Sheet List" tab when I select my cadd file then select "Publish" the option to "Publish using page setup override" it is grayed out (see attached image). The only work around I know of is to recreate a new sheet set file. Any help or ideas what is causing this and how to fix is is much appreciated.
Solved by Jay_B. Go to Solution.
Right Click on the Sheet Set Title>Properties>Sheet Set>Page setup overrides file> browse to the file containing your page setups.
Now you should see the Page Setups.
