Civil 3D Forum
Sheet Set Manager Override
2 REPLIES 2
773 Views, 2 Replies
I am using C3D 2014. The question I have is regarding the Sheet Set Manager. Under the "Sheet List" tab when I select my cadd file then select "Publish" the option to "Publish using page setup override" it is grayed out (see attached image). The only work around I know of is to recreate a new sheet set file. Any help or ideas what is causing this and how to fix is is much appreciated.
2 REPLIES 2
Jay_B
Right Click on the Sheet Set Title>Properties>Sheet Set>Page setup overrides file> browse to the file containing your page setups.
Now you should see the Page Setups.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
That fixed it. Thanks for the help!
Rail Community
