This post is to communicate yet another gripe to Autodesk.
Every time I try to select the text of an item in the open recent list the recent list will disappear before I can select it. I've discovered that I must carefully move my mouse pointer down the left column that precedes the entries in order to select any of them. Autodesk, could you please fix this so that anywhere on each item is selectable and the recent list stays open until the mouse moves off of it?
I, and I suspect others, would greatly appreciate it.
You don't happen to be using a non-Microsoft mouse or a trackball?
I use a Logitech Trackball but I connected a regular mouse (wireless) and had the same trouble.
