Civil 3D Forum
Sheet Set Manager - open recent
3 REPLIES 3
coopdetat
265 Views, 3 Replies
This post is to communicate yet another gripe to Autodesk.
Every time I try to select the text of an item in the open recent list the recent list will disappear before I can select it. I've discovered that I must carefully move my mouse pointer down the left column that precedes the entries in order to select any of them. Autodesk, could you please fix this so that anywhere on each item is selectable and the recent list stays open until the mouse moves off of it?
I, and I suspect others, would greatly appreciate it.
---------------------------------------------Signature--------------------------------------------
Civil Design Professional Since 1983 (Intergraph), AutoCAD since 1989
Windows 10 Pro 64-bit Intel﴾R﴿ Core﴾TM﴿ i9-12900KF CPU 3.19GHz; 32 GB DDR4 4266 Dual Channel RAM
nVidia Quadro RTX 4000; AutoCAD Civil 3D 2023.2.1 Update
3 REPLIES 3
tcorey
in reply to: coopdetat
You don't happen to be using a non-Microsoft mouse or a trackball?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
coopdetat
in reply to: tcorey
I use a Logitech Trackball but I connected a regular mouse (wireless) and had the same trouble.
gedgington
I just recently started having this identical problem. Just wondered if you've found the cause or solution. Gary
Rail Community
