When I use the SHEETSET command, the pallette is nowhere to be found. Anyone know how I can recall it to the desktop?
Solved by mathewkol. Go to Solution.
This didn't work for us. Any other suggestions for getting the sheet set manager back?
@Anonymous wrote:This didn't work for us. Any other suggestions for getting the sheet set manager back?
This one is crazy, and I have no idea why it works. It works for my machine, and a coworker just had the same problem and it worked for him. Simply unlock your taskbar (if locked) and move it to a vertical position on the side of your monitor and the Sheet Set Manager will appear on far right edge of the monitor. Move it in from the edge and you are good to go. It might appear beneath the task bar so you might have to move your task bar from side to side or to your second monitor, or even back to the bottom. Once the Sheet Set Manager is off the edge of the screen you can put your task bar back on the bottom of monitor if you like.
