Civil 3D Forum
Sheet Set Location
1 REPLY 1
582 Views, 1 Reply
Sheet Set Location
I have a few drawings that i want to create a sheet set for. The only problem i have is when i create a sheet set, when i browse for drawings, i only can choose one out of 4 drawings to add to the sheet set. the other drawings are linked to a different sheet set that i have no clue where it is. Is there someplace in Civil 3D to check where your sheet set is stored at or is there a way to remove any associations with previous sheet sets. I am using Civil 3D 2012.
1 REPLY 1
tyronebk
Make sure the variables SSMAUTOOPEN and SSLOCATE are both set to 1, then open the drawings that are associated with the other sheet sets. That/those sheet set file(s) should automatically open in the sheet set manager (SSM). If you look at the properties of the sheet set it should tell you the exact location of the file (or run the command SSFOUND). Close out of the sheet set file in SSM, or just close out of Civil 3D altogether, and either delete or rename the sheet set file. If another user has the sheet set file open, the file will immediately be recreated.
Rail Community
