I have a few drawings that i want to create a sheet set for. The only problem i have is when i create a sheet set, when i browse for drawings, i only can choose one out of 4 drawings to add to the sheet set. the other drawings are linked to a different sheet set that i have no clue where it is. Is there someplace in Civil 3D to check where your sheet set is stored at or is there a way to remove any associations with previous sheet sets. I am using Civil 3D 2012.
Solved by tyronebk. Go to Solution.
