I have recenly created layouts imported to a new sheet set and have created custom field properties that belong to both the layout sheets and the sheet set itself.
When inserting fields into the attributes of a block in paper space, some of the custom field properties (from sheets and sheet set) in the field manager are not there and some of the field properties that I can select do no display what I have input into the sheet set manager. There are other fields that do display correctly though.
I have used sheet sets mulitple times with no problems, so I am a bit confused to why this is happening.
Thanks for suggestions.
If this is happening to Fields that are block attributes, be sure you set the attribute to Preset when you create it.
Your Name
