Hi, everyone. We are having some major issues with Civil 3D 2008 SP2 and Sheet production. Our desired method of putting plan sheets together are to have all the Civil 3D design work in one file, and be able to xref that design file in to sheet drawings, and using the layer freeze to turn off aspects of the design that are not to be shown on those particluar sheets. However, some issues are cropping up that have us confused and frustrated.
One issue is that all surface labels seem to be referenced to a single layer defiend int the drawing settings. In our case, this is the C-TOPO-TEXT layer. But, our label styles put the labels on individual layers. When we are working in the sheet drawing with the design file xref'ed, the single layer controls the visibility of the label. So, when we try to turn off the spot elevations, style setting C-TOPO-SPOT-PR, They only turn off when the C-TOPO-TEXT layer is frozen. But, then our contour labels also disappear, even tho the style setting puts them on C-TOPO-MAJR-LABL.
Also, grading lines seem to be controlled by the active layer your on when you create them, not the layer name in the style setting. When we try to freeze out the grading lines, style setting C-TOPO-GRAD-FILL and C-TOPO-GRAD-CUT, the daylight lines remain, typically listed on layer 0.
And corridor lines are just as bad. our style settings place these on C-ROAD-CORR layers, but freeze those out, and certain corridor lines remain, like centerlines and daylight lines.
Our current solution is to export C3D files to ACAD, and explode blocks into ACAD elements, but this not only breaks the dynamic features of the information, but also requires some extra steps of 'cleaning' up the file to display them correctly. And, any change to the design file will require us to re-export and clean the files again.
How do you guys do it?
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
