AutoCAD Civil 3D General Discussion
*Expert Elite*
161 Kudos
Post 11 of 16
Re: Sheet print area from polygonal viewport?
10-16-2013 07:07 AM in reply to: peterfunkautodesk
OK then.  I am pretty sure a couple of yeara ago, sections would "re-organized" themselves.  I have had no need recently with the economy in the "terlit",
Thanks for your answer.
Bill
Member
0 Kudos
Post 12 of 16
10-16-2013 07:20 AM in reply to: wfberry
The sections do rearange when you change the Section view group plot style. But once I've decided how i'll do I won't be changing that so ok. Just frustrating when you can do something with a different softwere and not with Civil :smileytongue:
12 Kudos
Post 13 of 16
10-31-2013 11:41 PM in reply to: Solefio
The sections do Rearrange themselves
If you select a section and right click-> update section view layout.
They will update if you change the scale, or edit the group plot settings..
The sections won;t update though if try and add a new section in.. you can delete sections strangely though.. and it will re arrange..
Kapanther
Civil 3D 2014 (SP2)
Win 7 Pro x64 -DELL Precision Workstation T3500
Intel Xeon 3.3GHz (w3680) -24Gb Ram
NVIDIA Quadro 2000 (1GB)
ceethreedee.com
12 Kudos
Post 14 of 16
10-31-2013 11:50 PM in reply to: ceethreedee.com
Yes,, just tested polygonal viewports do not work...
even though i created a template with polygonal viewport
It still only shows the rectangular frame in model space...
although it doesnt seem to even get that right.. it seems to put all the text from the annotation outside the frame... So it gets cut off when you go into paperspace...
Bug??
Kapanther
Civil 3D 2014 (SP2)
ceethreedee.com
*Expert Elite*
288 Kudos
Post 15 of 16
11-01-2013 05:27 PM in reply to: Solefio
Kapanther, this is a different you need to have a data band on the bottom of every section view. Turn off all components so they can't be seen and make the title component on the left. Adjust the sizing until things look correct.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
12 Kudos
Post 16 of 16
11-03-2013 03:00 AM in reply to: mathewk
Lol its a good work around... Still annoying that it doesn't sort that out automatically....
Thanks for your help..
Regards
Kapanther
Civil 3D 2014 (SP2)
ceethreedee.com
Post to the Community
New Post
