We are having this problem a lot recently with our projects.
I have a 125 page set and I just got into modify a sheet and the surface and profiles are gone. I force a sync using "synchronizereferences" and voila everything looks as it should. I purge and audit, save and close. I reopen it and once again the surface and profiles are gone.
Any ideas? We are using C3D 2013 with service pack 2 installed
Thanks in advance
I noticed your related post Here
It's not going to be of much help for this project but by changing your workflow and utilizing multiple C3d source drawings it can offer more flexibility to work around this Syncing issue.
Civil 3d users should'nt have to do worry about this while trying to get a 125 sheet plan set out the door! I feel your pain!
In most instances, having Pipe Networks in their own source drawing and unloaded or detached from the plan sheets seems to make this problem go away in our workflow here.
Until AutoDesk gets this Dref synching issue resolved, this is the only means I've found to workaround it.
Thanks Jay. I've seen that other post, and it does work for some things, but I can't just unload my files. We are already talking of changing the way our files are structured because of this issue. Thanks for your help. Hopefully AutoDesk will get on this soon. Such a PITA
Jay - I'm trying to figure out some solutions for our future file structure and I'm curious, do you keep all your "Civil Entities" (surfaces, alignments, pipe networks) all in one drawing or are they all separate? We are going to have to start our files this way to avoid future issues but curious as the best way to go about it.
Thanks!
