Solved by Jeff_M. Go to Solution.
Does anyone know where to find a copy of this training class by Nick Zeeben? I'm having the same issue in C3D 2012. I can publish the catalog in a network location, create a registry file, load the catalog from anonther pc, but it still can't locate the dwg assembly file.
Thanks for the link Jeff. I'll try this today and see what happens.
This thread is marked as solved, but I can't get my subassemblies and assemblies to work on a shared tool palette. Is there perhaps something that wasn't mentioned? I'm trying this in c3d 2016...
After investigating this for a while I'm starting to believe this only works with ootb subassemblies. SAC generated subassemblies must be preloaded to the user's harddrive before a user can add a predefined assembly (with the previously mentioned subassembly) to a drawing using toolpalettes? Can somebody confirm this?
