Civil 3D Forum
Shapefile datum issue
28 REPLIES 28
Message 1 of 29
wsargent
807 Views, 28 Replies
PCPG has just released new data pertaining to Pennsylvania Geology. I am attempting to import the information into my project file that is on the NAD 1983, State Plane Pennsylvania North Feet coordinate system (PA83-NF) but AutoCAD is not reading the datum of the import file. I checked and the PRJ file is with the shapefile and the datum is defined in the file. Any help with this issue is appropriated.
The file can be downloaded here:
http://www.dcnr.state.pa.us/topogeo/openfile/folds.aspx
__________
AutoCAD Civil 3D 2016 SP3.0, built on: AutoCAD 2016 SP1, Map 3D 2016 SP2
Dell Percision T5810: MS Windows 10 Pro; Intel Xeon CPU E5-1620 v3 @ 3.50 GHz, 16.00 GB RAM, NVIDIA K2200 4.00 GB Memory
28 REPLIES 28
Message 21 of 29
MMorrison
in reply to: AllenJessup
Try the pics in the zip fle attached.
Martin
Message 22 of 29
wsargent
I might have to go that way, but was told to exhaust all other avenues before I did.
__________
Message 23 of 29
AllenJessup
in reply to: wsargent
Not really a bad suggestion. As long as your being given the time to figure it out. Great.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Message 24 of 29
wsargent
in reply to: MMorrison
Martin
What program are you using? That looks a lot easer than the interface I have (Civil 3D 2011).
The pictures are helpful, but because of program discrepancies (or user error) my data is landing thousands of miles south east and rotated approximately sixty degrees. When I was defining the datum I only found the two below tabs to impute the system data in.
__________
Message 25 of 29
MMorrison
I'm using C3D 2012.  I guess I should have used an older version.
The issue with your data being off is; you are picking a geodetic system and you should be picking non-geodetic/ellipsoid (Clark 1866).
Martin
Message 26 of 29
wsargent
I don't have access to Civil 2012 yet. Our IT staff has not upgraded the license file because most of the staff is still on the 2009 releases.
I attached the wrong image. The above discription is using the non-geodetic/ellipsoid (Clark 1866) setting.
I think the biggest problem I am having is that I cannot choose to use NAD 27 as a base datum like you do in step three of the images. It appears like I only have access to step four, defining the coordinate system, which is the two tabs that I provided screen shots of (unless I am missing something).
__________
Message 27 of 29
machadt
Hi Walter,
With the help of Martin (well detailed), I created the CS that you need. Please use this drawing that has the custom CS already assigned to it, as soon as you open the drawing you should have the new CS added to your library.
Hope this will help you.
Tatiana Machado
AEC-ENI Application Engineer
Message 28 of 29
wsargent
in reply to: machadt
That worked. Thans so much for the help.
__________
Message 29 of 29
machadt
It is my pleasure to help.
Happy Holidays to all!
Tatiana Machado
Rail Community
