I am attempting to import a shape file in Civil 3D 2014 and get an FDO error (see attached). I have performed this task nearly everyday for an entire year in 2012 with the same file, method, etc. I change my workspace to 'Planning and Analysis", select 'Map Import' and select my shape file...error!
Any ideas?
Justin
Can you attach the .shp file. If it's a bad .shp file, I will open up in a program I have and fix it.
the shape files are not bad, I download hundreds of these shape files from a state agency and have used them for about 5 years...they have always worked flawlessly in previously releases...
I encountered what you're talking about. I posted the fix on this thread...
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/MapExport-on-2014-Not-Working/td-p/3863200
