Hi all,
I need to generate a sewer profile. I am not using pipe networks. Just creating a profile of existing and proposed ground line. My storm sewer alignment goes thru some storm chambers. Say I have 4 chambers 50' long that are aligned next to each other (as in rows). the pipe enters the chamber at the top right area and exists at the bottom left area. can I create two alignments and have them in the same profile view? If my alignment goes from where it enters the chambers to the exit point of the chambers, it will be greater than 50 feet. I just want to show the 50' gap in the profile so I can show the 50' length of chambers.
Sounds like the SuperimposeProfile command might work for you.
Your Name
Your Name
