Hello everyone, When I label the sewer manholes the station, rim and name text come in at correct text height, but the invert in and out text height is smaller.
how can I fix this?
thanks in advance
Solved by drafter1411. Go to Solution.
Solved by Jay_B. Go to Solution.
Solved by wfberry. Go to Solution.
one other question I adjusted the text so it would show the word Rim and Station. I didn't see text for Inv In and Out although they show up. I want to add a space between colon and elevation.
Example:
It now shows like this INV IN:08.33 (No Space between colon and elevation)
I would like for it to show like this:
INV IN: 08.33 (space between colon and elevation)
thanks
Just enter a space with the space bar after the colon when you open up Composer for that label.
Bill
hi and thanks, Thats the problem I don't see where to add a space. I added the words Rim and STA and spaced them, but do not see INV IN or INV OUT in the composer. look at the screen shot
We can't see your style.
Try backing up a step and look at the "component name" on Layout tab of structure label style.
The Invert info is likely listed separately here in a different component, unless your using 2 separate labels.
