Anyone else having issues with the SSM and PUBLISH in C3D? We've been using the SSM in Land Desktop for some time, and we've noticed a lot more problems with it in Land Desktop 2007 than before, but nothing that compares with the level of frustration we've been experiencing with the SSM in C3D 2007.
Sometimes through lots of futzing around, we can get it working, by doing AUDITS, and by deleting and recreating DST files, or by creating new DWG and moving everything into them (basically recreating the DWG files from scratch). But that can be an awful lot of work, just to get the things to plot.
Like right now. I have a drawing with 2 layouts, and created a Sheet Set, adding the layouts as two pages in the SSM. Fields in both pages are updating correctly. But when I try to publish from the SSM, the PUBLISH operation fails, with the following message in the plot log: "ERROR: Layout not found".
This makes no sense. The SSM is correctly updating fields. I can close all drawings, and open the layouts from the SSM. But when I try to PUBLISH, I get "ERROR: Layout not found". I can PUBLISH Page 2 only, and I can PLOT both pages, but I can't publish Page 1, and I can't publish the entire Sheet Set from the SSM.
I also notice that when I type PUBLISH from the command line, only Page 2 shows up in the dialog. It's as if Page 1 doesn't exist. BUT IT DOES! And the SSM is correctly updating fields on page 1. So why can't the PUBLISH command see it?
Attempting to remove the layouts from the Sheet Set may not be working. I do that, and then try to re-add them, and I get the old "Layout may be part of a sheet set" warning, even though I just removed the layouts from the sheet set. This seems to be a standard 2007 problem, because we see similar stuff with Land Desktop, although it doesn't seem as bad. Somehow, the SSM and the drawings do not seem to be staying in synch with each other, and it seems to be worse in C3D than in Land Desktop.
There seems to be a TERRIBLE amount of confusion somewhere behind the scenes here. It's making it virtually impossible to use the SSM in Civil-3D, at least for PUBLISHing drawings.
Is anyone else having similar issues?
Sinc
