Hi!
I have a small field (5 by 5 meters) to be set out with about 40 points. Currently i use EOV (Hungarian National Coordinate System), thus each point has a lot of digits. I want to make the implemetor's job easier, so i want to move and rotate the CS near to my field.
I tried to use UCS, but the COGO points retained the "World" coordinates.
Do you have any idea how to carry out this without moving my whole drawing to the origin?
Thanks!
Solved by ctbailey. Go to Solution.
Thanks, Matt!
It is a perfect solution for truncating the digits, but i would like to rotate the CS as well, as it is shown below.
I think it can be solved with trigonometric functions, but isn't there an easier way?
I think this is a perfect example of a use for the "Transformation" tab found in Drawing -> settings.
We don't really want to MOVE or ROTATE the points, we just want to change the display of the points.
I would look into the Transformation tab, and then revise some of the labels to use the "grid" coordinates, instead of the "local" coordinates.
I tried to use the Transformation before but i didn' know about the grid coordinates.
Now it works perfectly! Thanks!
