Civil 3D Forum
Setting up a Sheet Set Manager Template
9 REPLIES 9
Message 1 of 10
boberdorf
10343 Views, 9 Replies
I want to set up a sheet set manager template which uses a specific client titleblock, which due to the work I do is quite frequent.
I would like to insert as many fields into the title block that refer to custom properties in the Sheet Set.  In particual some common fields point to the actaul Sheet Set custom properties (eg Client Name), and some point to the actual sheets custom properites (eg Title).  I have set up a sheet set with a range of custom properties attached to both the Sheet Set and the Sheet.
However, I cant figure out how to set up the titleblock template to read in this information for each new sheet I create.
I open my template file, insert fields as required and try to point the fields to the sheet sets file.  However I cant point to the custom properties for a sheet unless there is a sheet open.  When I do this, all new sheets are created with the fields using the original sheet values - I wanted to update these based on custom properties I set for each sheet.
Brian
9 REPLIES 9
Message 2 of 10
Joe-Bouza
in reply to: boberdorf
It has to be added to a "dummy sheet set to assigne the properties.
Required Reading=> HERE
Joe Bouza
Message 3 of 10
david.penney00
in reply to: Joe-Bouza
I read that link you stated, however i could not make head nor tail of what was being explained regarding the Template and the descriptions of the dialog boxes differed to what I was actually seeing....  Smiley Wink
Which comes first the Sheet set or the drawing Template (dwt file)? and how to combine the two?
Based on what I had to do with two existing drawings sheets, they were a nighmare....
Cheers
Message 4 of 10
Joe-Bouza
It is confusing at first. You are making a dwt from a SSM drawing that will contain your borders and field for creating a sheet on the fly. As well as a prototypical dst file to create A sheet set from existing. Explore the sample SS and it will get more clear fo you. Hang in there it will click
The reality is you dont have to create sheets by SSM thus not require a DWT but if you want to leverage to the max you'll want that
Joe Bouza
Message 5 of 10
boberdorf
in reply to: david.penney00
Being a beginer as well, I think the process is to:
  1. start the sheet set and use your normal template file as a starting point;
  2. Create a drawing, and modify it to suit with fields;
  3. Save this file over the initial template file;
  4. Then create the drawings from this.
Message 6 of 10
Joe-Bouza
Correct
Joe Bouza
Message 7 of 10
Yeaht the 43 page pdf is hard to fallow. Is the a video tutorial somewhere?
Message 8 of 10
Yeaht the 43 page pdf is hard to fallow. Is there a video tutorial somewhere?
Message 9 of 10
kbiggs
Heidi Hewett has quite a lot of information on sheet sets on her blog. Some of it may be dated, but it is still valid:
http://autocadinsider.autodesk.com/.services/blog/6a00d8341c99d753ef00d8341c99da53ef/search?filter.q...
Keith Biggs Chair,
CAD Standards Committee & Senior CAD Technician
R.F. Binnie & Associates Ltd.
Leading in Quality: OQM certified March 2013.
Message 10 of 10
Joe-Bouza
Don't try to absorb the whole document in one sitting, break it down into managble task, for you.
I sugeest as a tutorial use one of the OOTB sheet sets an tear it apart. Its just one of thos things you are going to have to get under the hood and scrape your knuckles.
I don't know of any vids but there are the AU class and Youtube probably has some, but take them lightly and refer to Sheets happen upon viewing because many people have many interpertations of how to use it
Its hard to follow because its new to you.
Joe Bouza
Rail Community
