Civil 3D Forum
Setting Survey Points on a Pipe Network
2 REPLIES 2
342 Views, 2 Replies
Does anyone know how to set stakeout points on a pipe network?
I have an alignment from the engineer that also has a pipe network associated with it that I would like to automatically set points vertically and horizontally on (like I can do with a regular alignment/profile).
2 REPLIES 2
rl_jackson
The pipe alignment should be no different than another alignment.
The only thing that would be different is the Stakeout of the structures themselves.
Rick Jackson
Survey CAD Technician VI
wfberry
I have found that the easiest way is probably what you are referring to using alignment/profile.  I just draw a final grade profile along the pipes invert lines and use this for pipe offsets with invert elevations.  Of course I usually have a separate alignment along the C.L. of the pipe.
Bill
Rail Community
