Show only
Search instead for
I cannot seem to get my lineweights to print without fading each color dependent on the color I am using. Even if I set all the line weights to the same thickness the lines still print out at different shades from each other. Example: red prints much darker than yellow or cyan. I want them all to print at the same shade only with different widths. I have looked in the forum and have not been able to find anything helpful on this issue. I have set up my plot style table witht the lineweights as listed below (inches):
red 0.010
yellow 0.014
green 0.010
cyan 0.018
blue 0.008
magenta 0.014
white 0.003
Please help. I have spent a lot of time trying different things and have gotten nowwhere.
Thanks in advance.
Edited by: Weather25 on Jun 2, 2010 6:15 PM
Can you attach a screen shot of your plot style table?
Matt Kolberg
Global CADD Systems - A division of Cansel
"Weather25" wrote in message news:6401505@discussion.autodesk.com...
> below (inches):
> red 0.010
> yellow 0.014
> green 0.010
> cyan 0.018
> blue 0.008
> magenta 0.014
> white 0.003
> gotten nowwhere.
> Thanks in advance.
Here it is. In a seperate reply I will also attach a screen shot of my print preview scree that shows how it plots out. Yellow, Cyan and Magenta print out really light even though they are a thicker lineweight.
I haven't done CTB in some time...but I think the issue is the Virtual
Pen Number...or Gray Scale...
Matthew Anderson, PE
set all your colors to Black instead the actual color. Now all will print
the same color, with a different thickness.
(inches):
red 0.010
yellow 0.014
green 0.010
cyan 0.018
blue 0.008
magenta 0.014
white 0.003
gotten nowwhere.
Please tell me where you set the colors to black. I'm assuming you did not have to change all the screen layer colors... I was an AutoCAD guru a decade ago but the wheels have fallen off 🙂 Thanks
