When adding feature lines to a surface you are given a prompt to specify description, weeding factors, supplementing factors, etc... how do I change the settings of these numbers(the supplement, and weeding factor)?
Solved by awood. Go to Solution.
In Settings - under Surface - Command Settings - AddSurfaceBreaklines.
See attached image.
HTH
AWood
