C3D 2012 SP4
Win 7 Pro
When creating the short cut folder you have the option of using a project template. Instead of browsing for it all the time , can a permanent path on a network be set to look for the project template everytime?
Solved by Jay_B. Go to Solution.
It can be specified in the registry Here
Pretty sure if you're running 2012 you'll find it here:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R18.2\ACAD-A000:409\AEC\Directories\ProjDir\
As always use caution when editing the registry.
You might start here, this may achieve your goal.
Rick Jackson
Survey CAD Technician VI
