troma
Message 11 of 17 (499 Views)
Re: set multiple polyline elevations for contour data
11-13-2012 11:21 AM in reply to: mikeevans
The UKIE Toolbox is presumambly available to users in the UK and Ireland.  Since the OP is using imperial units, I doubt it is an option.
Why such a tool would be provided to some users and not others I can't imagine.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Jeff_M
Message 12 of 17 (495 Views)
11-13-2012 11:33 AM in reply to: troma
It can be installed from any C3D installation..although if you use Deployments I would imagine it would need to be included in that.
You can add the UKIE Content pack after installation by going to Windows' Remove programs, select the version of C3D you are using, at the screen to choose to Uninstall, reinstall, repair, etc., choose Add or Remove Features, then check the UKIE Content.
troma
Message 13 of 17 (491 Views)
11-13-2012 11:42 AM in reply to: Jeff_M
Good to know.
Still don't understand why a tool like this would be hidden away in a country kit, even if it is available to all.
*Pro
dgordon
Message 14 of 17 (440 Views)
11-29-2012 10:33 AM in reply to: mikeevans
Unless you have that tool available there is no need to change the 2d contours to 3d.   I did find a tool I wasn't aware of in the Modify Tab under Design that allows you to directly edit the elevation of a polyline without having to bring up the properties dialogue box.   Unfortunately it only works on one polyline at a time.
Definately use the polyline edit multiple and join the 50 ft segments together rather than editing each segment.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Valued Contributor
C3D_TomR
Message 15 of 17 (430 Views)
11-30-2012 02:15 PM in reply to: kas022
New Member
tomtrubo
Message 16 of 17 (135 Views)
03-28-2014 06:15 PM in reply to: C3D_TomR
sorry to bring this subjetct back to light after that much time, i am what u can call a completeley new CAD user, i was given a dwg file with what i am suppose to call the contours, so i tried making a surface made up of this contours and it did not work at all, then i tryed to check the elevation of each of the lines and the properties menu wont show me any elevation at all, i mean i cant even check if there is an elevation or they are all plane, if u think u can help me i would appreciate it a lot, srry for my english am from Colombia, trying to learn and get a good grade in this...
neilyj
Message 17 of 17 (122 Views)
03-29-2014 02:43 AM in reply to: kas022
Can you post a screenshot of the properties pallette when you have a contour selected
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
