Solved by Jeff_M. Go to Solution.
Solved by Lisa_Pohlmeyer. Go to Solution.
Mark Green
Working on Civil 3D in Canada
You can set the command settings directly. Go toe Settings->Alignment->Commands->Create alignment entities, right click, Edit command settings, Create from Entities.
While troma's suggestion will work, I don't like having that setting on as it can adversely affect other settings that you may only want to change once. But as long as you are aware of it's setting it can be useful (I haven't used it in 5 years, better to change each command setting as you need, imho).
Mark Green
