Civil 3D Forum
Serious Reactor Error
7 REPLIES 7
Message 1 of 8
andram-teco
484 Views, 7 Replies
Has anyone ever seen "Serious Reactor Error" (see attached)?
I was trying the EXPORTOAUTOCAD command when the error popped up. It was not a huge deal. I exited out of the drawing,  reopened it and it worked fine.
It's just something I had never seen before
I wonder if I should find a bomb shelter somewhere . . .
7 REPLIES 7
Message 2 of 8
machadt
in reply to: andram-teco
Hi Andra,
Do you Have any custom routines loaded on your Civil 3D?
Tatiana Machado
AEC-ENI Application Engineer
Message 3 of 8
andram-teco
in reply to: machadt
Hi Tatiana,
Just one: MdiTab18.arx
Thanks!
Message 4 of 8
machadt
If don’t mind me asking, what this routine does??...
The routine is the one causing the error message, it is conflicting with another portion of the software…
Tatiana Machado
Message 5 of 8
MarySeufert
See this Shaan Hurley blog... Drawing Tabs
~ Mary
EXPERT ELITE MEMBER
Message 6 of 8
machadt
in reply to: MarySeufert
Thanks for the link Mary,
If that is the tool that you are using, it was create it to be use on ACAD 2010, with that been said some times this type of tools could work on newer versions but it looks like something is conflicting with 2012, that is a programming error.
Tatiana Machado
Message 7 of 8
andram-teco
Thanks Mary & Tatiana,
If I run into the error again, I'll remove the tool. Don't want to suffer from any fallout after all.
Message 8 of 8
MarySeufert
If you need a replacement for MDITabs, I use this Drawing Tabs by CAE-Link, which is compatible with 2007-2012 and free! I haven't run into any issues so far on any of my ACAD versions.
~ Mary
EXPERT ELITE MEMBER
Rail Community
