andram-teco
Message 1 of 8 (329 Views)
Serious Reactor Error
329 Views, 7 Replies
02-01-2012 12:42 PM
Has anyone ever seen "Serious Reactor Error" (see attached)?
I was trying the EXPORTOAUTOCAD command when the error popped up. It was not a huge deal. I exited out of the drawing,  reopened it and it worked fine.
It's just something I had never seen before
I wonder if I should find a bomb shelter somewhere . . .
Thanks for the link Mary,
If that is the tool that you are using, it was create it to be use on ACAD 2010, with that been said some times this type of tools could work on newer versions but it looks like something is conflicting with 2012, that is a programming error.
machadt
Message 2 of 8 (272 Views)
Re: Serious Reactor Error
02-02-2012 04:34 PM in reply to: andram-teco
Hi Andra,
Do you Have any custom routines loaded on your Civil 3D?
Tatiana Machado
AEC-ENI Application Engineer
andram-teco
Message 3 of 8 (250 Views)
02-03-2012 09:56 AM in reply to: machadt
Hi Tatiana,
Just one: MdiTab18.arx
Thanks!
machadt
Message 4 of 8 (242 Views)
02-03-2012 10:57 AM in reply to: andram-teco
If don’t mind me asking, what this routine does??...
The routine is the one causing the error message, it is conflicting with another portion of the software…
Tatiana Machado
MarySeufert
Message 5 of 8 (226 Views)
02-06-2012 10:05 AM in reply to: machadt
See this Shaan Hurley blog... Drawing Tabs
~ Mary
_______________________________________________________________________
Normal people believe that if it ain't broke, don't fix it.
Software Engineers believe that if it ain't broke, it doesn't have enough features yet.
machadt
Message 6 of 8 (217 Views)
02-06-2012 10:32 AM in reply to: MarySeufert
Tatiana Machado
andram-teco
Message 7 of 8 (198 Views)
02-06-2012 01:20 PM in reply to: machadt
Thanks Mary & Tatiana,
If I run into the error again, I'll remove the tool. Don't want to suffer from any fallout after all.
MarySeufert
Message 8 of 8 (188 Views)
02-06-2012 02:02 PM in reply to: andram-teco
If you need a replacement for MDITabs, I use this Drawing Tabs by CAE-Link, which is compatible with 2007-2012 and free! I haven't run into any issues so far on any of my ACAD versions.
~ Mary
