Question: Where can I find a list of the Autodesk Knowledge Network support solutions that were created and/or updated in the month of September?
Week One:
AutoCAD Map 3D 2015 now supports Microsoft SQL Server 2012 Standard Edition
Autodesk 2015 product displays a 0.0.0 error
Can AutoCAD be run without a user?
Create sample lines from existing polylines not working as expected
Exploded Civil 3D labels taking current layer’s color
Fatal Error When Launching AutoCAD
Ghost lines and artefact issue appears when zooming in/out with Nvidia GeForce 650M on AutoCAD 2015
How to change the paper background of a layout in AutoCAD
How to use a different color book
Migration of Custom Settings to Civil 3D
The “Copy Block Definition and Assign” command is missing in AutoCAD
Unwanted lines show up on plotted output from AutoCAD
Week Two:
Adding contour label makes contour lines shift
Are there any known AutoCAD compatibility issues with Office 365
AutoCAD Civil 3D crashes while plotting large files
Block command does not convert selected objects to block definition
Change space does not work on annotative objects in AutoCAD
Default DWF display is zoomed into sheet corner in Design Review
Error: “Unknown command” with all commands after loading custom cui or cuix file in AutoCAD
How to add user defined flow data for certain duration into Storm and Sanitary Analysis
How to disable view transitions when clicking on the ViewCube in AutoCAD
How to reset AutoCAD to defaults
In KY83F, Bing or WMS data does not display west of -87 degrees longitude
Keyboard function keys do not work in AutoCAD
Merge AutoCAD Layers
Odd graphics display when working with a high resolution/high dpi monitor in AutoCAD
Orbit hangs for several minutes in AutoCAD with an NVIDIA graphics card
Plot preview is in grey scale
SNAPGRIDLEGACY system variable does not work
Tolerance dialog box displays letters instead of symbols in AutoCAD
Valid Licensing Combinations for Autodesk Vehicle Tracking
When working with Autodesk Vault Thin Client the button for Autodesk Design Review is not active
Where can I find the Civil 3d Service packs
Week Three:
Adding image produces “SAXParseException: Invalid document structure” error
Commands not working in a viewport in AutoCAD
Data shortcut in prospector do not load
Error: “Unable to perform the requested action. This drawing was last edited with model documentatio...
Error: Sectioning plane does not intersect the selected solid in AutoCAD 2015
How to Access Online Vehicle Libraries
How to change text size on the ribbon and toolbars in AutoCAD
Missing Vault projects in Prospector
Offline help fails to launch after installation
Points appear when inserting drawing as block in another drawing in AutoCAD
Pressure pipe inside diameter label shows as “???”
The specified provider is not registered
Unwanted linework appears when opening drawings in AutoCAD 2015
When opening AutoCAD, we get multiple errors related to acecore.dll.
Zooming and panning in a layout with an activated locked viewport gets stuck in paper space
Week Four:
2012 suite install fails
After the update of the Autodesk Application Manager, the program crashes when trying to update soft...
ArcSDE direct connect to Postgre
Bad definition of FENCELINE1 at line XXX when loading a linetype
CAD Standards Plugins missing
Can the Civil 3D Junction and Vehicle Tracking Roundabout tools create a single corridor to include ...
Can you assign pipe properties to a pay item formula
Cannot select certain objects through viewport
Civil 3D 2015 Extension Modules not loading on Korean version
Curve correction tolerance
Custom pressure pipe part not showing the correct compass angles
Excel crashes after installing AutoCAD 2015
How to use reality data / point clouds in AutoCAD 2015
Internal Error: !saveres.cpp@154: eFilerError in AutoCAD
Object Viewer visual style is not displayed as expected
Pipe network headwall showing wrong direction in profile
PLOT or PUBLISH of drawings containing raster images is slow or crashes AutoCAD
Polylines are thickened by PEDIT > Width command, but displayed as hollow lines
Section profile grades do not show in Civil 3D 2015
WFS layer returns ‘500 Internal Server Error’
