Active Contributor
dbinkney
Message 1 of 8 (3,060 Views)
Send LAYER to back in display order. Not entities, the entire layer
3060 Views, 7 Replies
05-06-2011 08:03 AM
Any advice on how to send an entire layer to the back in display order, not just entities?
Civil 3D 2008
Joe-Bouza
Message 2 of 8 (3,054 Views)
Re: Send LAYER to back in display order. Not entities, the entire layer
05-06-2011 08:19 AM in reply to: dbinkney
you have to make a selection set. qselect all enties by layer
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Active Contributor
dbinkney
Message 3 of 8 (3,049 Views)
05-06-2011 08:24 AM in reply to: Joe-Bouza
Thanks! I will give that a shot.
Honestly, I am kind of astonished that there's not an easier way to control layer orders.
Sinc
Message 4 of 8 (3,046 Views)
05-06-2011 08:29 AM in reply to: dbinkney
AutoCAD has never used that sort of system to control draw order.  Instead, it allows us to control draw order by individual objects.  This gives us more flexibility, but it can be argued that it gives us TOO MUCH flexibility, and controlling draw order on a per-layer basis would work better in many situations.
Given how many years AutoCAD has been the way it is, however, I wouldn't hold my breath on seeing this change any time soon...
Sinc
mathewk
Message 5 of 8 (3,026 Views)
05-06-2011 11:09 AM in reply to: dbinkney
Incidentally, there is a tool on Autodesk Labs that will do this.
http://labs.blogs.com/its_alive_in_the_lab/2011/01/january-adn-plugin-of-the-month-draw-order-by-lay...
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Member
ITTCowboy
Message 6 of 8 (2,000 Views)
02-15-2013 12:45 PM in reply to: dbinkney
I know this is an old thread, but Im having trouble loading the dll file. This is what I get when I use the NETLOAD command:
Cannot load assembly. Error details: System.IO.FileLoadException: Could not load file or assembly 'file:///C:\Program Files\Autodesk\AutoCAD 2012 - English\adnPlugin-DrawOrderByLayer.dll' or one of its dependencies. Operation
is not supported. (Exception from HRESULT: 0x80131515)
File name: 'file:///C:\Program Files\Autodesk\AutoCAD 2012 - English\adnPlugin-DrawOrderByLayer.dll' ---> System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework.
This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
   at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName
assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean
   at System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile,
Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm
hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks,
StackCrawlMark& stackMark)
   at System.Reflection.Assembly.LoadFrom(String assemblyFile)
   at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
   at loadmgd()
mathewk
Message 7 of 8 (1,995 Views)
02-15-2013 01:00 PM in reply to: ITTCowboy
It was created a while ago.  it's probably not compatible with your version of AutoCAD.  In the link it says it was tested on 2007, which likely would make it not work for 2010 and above.
Matt Kolberg
troma
Message 8 of 8 (1,992 Views)
02-15-2013 01:19 PM in reply to: ITTCowboy
Check out Lee Mac's lisp for this
http://lee-mac.com/layerdraworder.html
Credit where credit is due! Give kudos or accept as solution whenever you can.
