AutoCAD Civil 3D General Discussion
Tomosara
Message 1 of 4 (167 Views)
Accepted Solution
Selection within the same layer
167 Views, 3 Replies
01-25-2013 12:14 AM
Hi!
If I have one layer containing different kinds of objects in different colour, is there any way I can select all those of one color? For example, I have houses in magenta and roads in white but in the same layer. If I mark a house and use Select Similar the entire layer will get selected although I just want to select the houses. Can I do a selection based on the colour they have?
Try using the Quick Select method (should be on right click)
*Expert Elite*
neilyj
Message 2 of 4 (166 Views)
Re: Selection within the same layer
01-25-2013 12:17 AM in reply to: Tomosara
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Tomosara
Message 3 of 4 (161 Views)
01-25-2013 12:31 AM in reply to: neilyj
That totally did it =) Thanks!
*Expert Elite*
neilyj
Message 4 of 4 (154 Views)
01-25-2013 12:47 AM in reply to: Tomosara
Excellent :smileyhappy:
Can you mark the post as a solution as an aid to others in the future (and Kudos is gratefully acccepted as well..!!!)
neilyj
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
