Civil 3D Forum
Selection within the same layer
3 REPLIES 3
Tomosara
265 Views, 3 Replies
Hi!
If I have one layer containing different kinds of objects in different colour, is there any way I can select all those of one color? For example, I have houses in magenta and roads in white but in the same layer. If I mark a house and use Select Similar the entire layer will get selected although I just want to select the houses. Can I do a selection based on the colour they have?
3 REPLIES 3
neilyj666
in reply to: Tomosara
Try using the Quick Select method (should be on right click)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Tomosara
in reply to: neilyj666
That totally did it 😃 Thanks!
neilyj666
Excellent Smiley Happy
Can you mark the post as a solution as an aid to others in the future (and Kudos is gratefully acccepted as well..!!!)
Rail Community
