If I select objects thru any function using a crossing everything works fine. If I select them one by one-it will only do the function on the last object selected. talking about functions such as move and copy. I am using Civil3D 2012.
If I type-MOVE-and then M- and select one by one things work. Doing this in different drawings.
Thxs. for the help.
David
Solved by Pointdump. Go to Solution.
Solved by Jeff_M. Go to Solution.
David,
From the Help Section:
"To access the (over 500)AutoCAD system variable settings, enter SYSVDLG at the command line or in the Civil 3D workspace, click Express tabTools panelSystem Variables. The following dialog box is displayed as shown in figure 14, providing a convenient interface for reviewing system variable descriptions and changing their settings."
Dave
Dave Stoll
Las Vegas, Nevada
