2014
Is anyone else experiencing weridness when trying to select items for parcel and pipe network tables?
I tried to window select parcels with the layer manager layers set it and it only grabbed about 2 out of 30.
I tried to select the list in the prospector tab and it wouldn't pick any.
I finally got something sort of useful by isolating just the layers with the parcels to select. I had to unisolate the layers to see the table.
I didn't have any luck trying to pick pipe network items from the prospector tab either.
I guess that isn't a function?
I didn't have any luck trying to delete extra items from tables. The only feedback I got was that the delete function didn't work. F1 didn't have anything useful.
The next time I will try to remove by picking the items in model space again and see if it was just a bad CAD file.
I don't do much with pipe networks (haven't done any engineering in a while), But I can definitely say that parcels can be snickety at times and you may want to restart C3D, and if the problem still exist do an audit on the drawing to see if it resolves the problem.
Although the stability of parcels has improved its still got a ways to go IMO, and could use some additional functionality as well, very little has change in quite some time.
Rick Jackson
Survey CAD Technician VI
